Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: ATC 70 headlight
    Beaver Falls, PA
    2,666
    ATC 70 headlight
    Hey guys, can anyone show me what a 70 headlight is supposed to look like? I've seen them on ebay, but not sure if they are a complete unit, or just a replacement housing. Mine has a home made light on it right now, and I'd like to put it right.
    Baltimore, MD
    6,088
    The only 70s that were suppose to have a headlight and taillight as an option officially was the 73 for sure and maybe the 74, but not sure on that. Otherwise, you are kind of wide open as to what to use. 73 headlight option was of course the atc90 roung headlight with the metal bucket and the light switch in the top of the bucket. The brackets needed to mount the headlight and taillight are now very scarce, meaning expensive. I'm not sure if the color of the headlight bucket was to match the trike color of orange or if the bucket was meant to be black or maybe silver like the forks. The headlight and taillight as well as the brackets were early us90 parts. You could use universal headlight brackets like I did on one of my old 70s and use a 90 headlight. The taillight brackets are just a tad harder, but I'm sure some of the fab guys on here can come up with something. There is even a 1 year only square headlight bucket that used the same headlilght switch that the atc90/early 110 used, but they are getting harder to come by. Then of course you had the later atc110 light switch on the left side of the handlebars as well. So there are options. And I've seen lights with various waterproof and non waterproof switches, some looking more professional than others. As far as 78 and later 70s, I never knew of an official headlight or taillight. If you wanted to mount a small speedo or wanted something really fancy, I'm sure you could use the headlight/speedo assembly from a z50 or ct70, that would seem like it would be pretty trick. And if you didn't want to mount a speedo, they came with a neat little Honda logoed block off plate. And a really modern taillight would surely be a nice little led unit of some kind.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    i have a small PIAA halogen fog light on the front of mine right now. i havent gave her power yet. The light is very small, outs out alot of light. Maybe ill hook it up today and see how it works.
    This is pretty much the light. only just grey without that flashy blue ring. It looks normal, not like eurotrash....
    The bracket is the same on mine just had to reverse it and put two notches in it and it bolted straight on. current/wattage draw is the only hitch i cannot find about the light itself... hope its not much.
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Des Moines, IA
    1,303
    I installed a rectangular one from Beatrice Cycle on mine. Here's the link: http://www.dratv.com/athekitinwo.html
    After I did all this, I saw some others that use the round ATC90 style headlight with the switch right on the bucket. The ATC90 headlight seems more "authentic" somehow, which may be silly since it was never an option. However, mine is an '85, and all '85's had square headlights. I did not bother to install a switch. My son rides this, and I really wanted the headlight on at all times, so I left it out.
    Here's a pic of my son's. The other thing I really like about this headlight is that it's super bright and good beam, compared to the ATC90 headlight. There was a specific bulb choice that I made that made all the difference, but now I can't remember what it was...15W or 25W. I need to see if I can find that thread.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Beaver Falls, PA
    2,666
    Thanks guys, that's just what I needed. I like both ideas, I may try to do a combination of the 2... when I do, I'm sure I'll be asking wiring questions... lol
    Monroe MI
    5,787
    Lancaster, PA
    1,738
    The optional Headlight/Taillight kit that was made for the 73-74s but fits all ATC70s. I have both but it was a long search and many peices here and there to make a complete kit.
    good luck finding a kit, VERY RARE, the head light and taillight are the same as an ATC90 but the mounts are different. You could use an ATC90 head light and the Dr ATV head light mounts and fab up a tailight mount, and keep an eye out on ebay for an ATC90 or US 90 tailght assy.. Then just make your own wire harness, the lights are turned on by the switch on the headlight. I also know Vintage Motorsports was working on an exact repro in the wiring harness
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Feb 2008
    Pennsylvania
    2,305
    Here is my atc70. It came with the round bucket headlight, but it was broken and dented. I replaced it with this 110 square bucket with the switch on the top. I used the original brackets. Worked great. I also like how it looked.
    Attached Thumbnails Attached Thumbnails DSCN2109..jpg   DSCN2107..jpg   DSCN2108..jpg
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    Beaver Falls, PA
    2,666
    sweet... I'm liking that 110 headlight too... and thanks for the diagram... so many choices now
    Dec 2007
    Quebec,Canada
    1,013
    I use a CT70 headlight with the bracket
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Baltimore, MD
    6,088
    I thought for sure the 90 mounts and 70 mounts were the same. Thanks for clearing that up. Thanks for posting up the page and the numbers too. Bruce since you have the A+ frame, what is the width of the rear grabbar?
    Nicholson 185s
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    HERES A SNEEKER OF A NEW PROJECT,, HEADLIGHT,,
    Beaver Falls, PA
    2,666
    atc500x, that is the sweetest 70 ever.... love it... did you cut the ears off the ct70 and weld them to the forks?
    and Kasey, that's awesome... where'd you get red tires?
    Dec 2007
    Quebec,Canada
    1,013
    Quote Originally Posted by atc350xer View Post
    Yes I cut the ears on a ct70 fork and weld it on the atc70 fork.the headlight bucket is a atc90 with the off/low/hi switch
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Nov 2002
    460
    Hey Guys,
    I do have reproduction wiring harnesses in stock they were made to exact specs as the factory honda harness for the 1973 model but will work on any year atc70, and it is made to work with the factory honda atc90 front headlight assembly and atc90 rear tailight. keep your eyes out soon I will have full lighting kits avalible just like hondas . I had tooling made to reproduce the factory chrome headlight brackets they are in production now they are 100% identical to hondas US90 chrome brackets cannot tell if you held them side by side , and i have a huge inventory of oem buckets , headlight glass and chrome bezel and light switches and rubber mounts so I can offer a complete kit that will correct as came from honda I dont know any pricing yet as most of the parts used will be authentic Honda NOS stuff . but keep your eyes out they are coming soon you might see tailight brackets also in the near future for the atc70s .. check out our sites foir any new products www.vintagemotorsports.net Mike
