Results 1 to 7 of 7
Thread: 200x lifan motor questions
    Daltons200x's Avatar
    Daltons200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Levittown, PA
    183
    hey guys, i tried searching but didnt really come up with what i was lookin for. im just lookin for some info on the 200 lifan motors.im buiding a 200x for my dad and instead of tryin to save the thrashed motor it looks like it will be more cost effeciant and reliable to just toss in a 200 lifan. he could also use the electric start scince his knees and all arent what they used to be. my main questions are is the 200 lifan motor just like a 200x with electric start? like manual clutch, 5 speed and all. also im sure i read that the chinese motors are good if left alone and u dont want to modify them(whitch i dont). is this true? finally, im not quite sure were to go to order the engine. like should i go to ebay(rather not). or is there a site i can get them stright off of?
    Thanks in advance, Dalton
    Rides:
    1983 suzuki alt50
    1985 honda 200x
    Feb 2009
    michigan
    2,387
    i have this same motor,it is fine.i put mine in an atc 185s.the only thing youll have trouble with is the rear kick start.if using the electric start it wont be a problem.will bolt right in.make sure you use the 200x carb mount not the lifan one.
    1985 ATC 250R
    . Team Red Trike
    Jun 2009
    Tunkhannock,Pa
    904
    yes they are pretty much the same as the 200x engine the lifan motor has little bit bigger bore 198cm i think were the 200x is 192cm
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Feb 2006
    Texas
    738
    Quote Originally Posted by Daltons200x View Post
    Hi there Dalton. There are 2 versions of the motor: there's OHC and OHV (pushrod engine). If you can, go with the OHC, it's a little harder to find (I think Hooper Import has them). Then there the sprocket, the one that comes with these engines is NOT for a 520 chain but a 428, in other words, it won't fit the 200X chain and you MAY have an alingment issue, you MAY or MAY NOT. If you do, youll need the very expensive "wonder sprocket". Make sure you use the right one.
    E-bay has the best prices on these motors that I have seen, but only for the OHV, nobody on there seems to have the OHC. If you don't want to buy it from e-bay, you'll probably pay a lot more That's really your call. Get yourself the corect wiring, fab something for a batery (some people put it inside the stock airbox) and you should be rolling.
    The engines are good and almost bulletproof from what I have read and 99% of whoever has them are very satisfied with them. For less than the price of repairing your old 200X engine (great engine I must say) you can get yourself a brand NEW one. And that my friend, you can't beat.
    Try here:
    http://www.hooperimports.com/product...pf_id=200ccV-H Over Head Cam
    http://http://www.hooperimports.com/...x?pf_id=E2005M Over Head Valve
    This is e-bays Lifan. You'll be shocked at the price difference betwen e-bay and hooper imports: http://http://cgi.ebay.com/ebaymotor...Q5fAccessories Most of the time e-bay can be your friend.
    Dr. ATV also has some parts (mostly for the smaller lifans) and good info.
    http://http://www.dratv.com/newreen.html
    Hope this helps a bit.
    TORKER.
    THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
    Feb 2009
    michigan
    2,387
    its true you have to get a new front sprocket,but you should put new chain and sprokets on anyway.i found a place that sells the correct sprocket for the usual cost
    1985 ATC 250R
    . Team Red Trike
    Mar 2009
    Levittown, PA
    183
    thanks guys this is a big help. wiring isnt a problem because i have a freind who is in electro mechanical at our local tech school and need a senior project. so hes offerd to build me a new wiring harness for my 200x and a wiring harness for my project x whitchever way i go with it. i just wanted to amke sure it was close to a 200x feel when riding just having the advantage of electric start and the fact that it a brand new engine so my dad wont have get stuck out on the trails. also if i buy him a brand new engine then i have a whole basket of engine parts that i can save as spares for my bike lol.
    P.S. thanks for not getting agrrivatted at me because i relize this is a pretty common question for the forums but i can never seem to find exactly what i need in the serches. ive prettymuch decided on getting the engine instead of tryin to pice back together my basket case motor and just wasnt sure wear to start looking for one.
    Thanks again, Dalton
    Rides:
    1983 suzuki alt50
    1985 honda 200x
    Feb 2006
    Texas
    738
    Well, there you go!!!
    Now, go build your pops a fun trike!
    TORKER.
