Results 1 to 15 of 21
Thread: What's the difference between Honda "s" "m" "r" etc?
    MA
    384
    I see many trikes have the same model with a differen letter. 200s, 200m, etc.
    Does the letter designate something specific across the board? Or is it just random?
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    for honda the s is for "service" and r is for race es is electric start as for the rest i'm not sure, i may be worng on the s,r,and es?
    Beaver Falls, PA
    2,666
    I always thought "S" was for "sport"?
    COLORADO
    685
    S,E,ES,M are usually utility models, X,R, and SX are sport or racing.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Sep 2008
    845 New York
    2,302
    if you run a search a couple long threads about this should pop up.i think atctim has the specifics in one of the threads but i know the m is e-start
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Worcester, MA
    1,117
    From what little knowledge I have:
    S = no reverse, no elec. start. Chain drive
    ES = Elec. Start, reverse?, most are shaft drive (wasn maybe one year that was chain? 84 BR?)
    M = Same thing as S but with elec. start. Larger gas tank + tires, also.
    R = 2 stroke racing bike
    E = Not sure
    X = 200s but with manual clutch, suspension frame, kick start.
    Apr 2008
    Biloxi, MS
    149
    Not to hijack this guys thread but will the fenders of a 200m fit a 200s?
    big yeller's Avatar
    big yeller is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    southeast texas
    247
    i thought the 84 br was a 200e??? a 84 br is chain driven
    1984 yamaha 200k
    1985 honda 70...some times swap the 125 lifan for fun
    1984 honda 200es
    1985 honda 200x
    atvs:
    2013 Honda Rancher 420 ES
    Dec 2009
    Rochester, NY
    37
    Number is the engine size, letter is a code for the features on the trike. The letters don't actually "stand" for anything.
    gsw902's Avatar
    gsw902 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    sanford nc
    153
    I am pretty sure the 84 big red was a 200 es and shaft drive. the 83 was 200e and chain drive.
    85 atc 200s
    85 200x ( auto x project
    03 suzuki ozark 250
    Feb 2006
    north of buffalo
    557
    84 br's were shaft. prior were chain. 85 and 86 were 250cc shaft and kick start.
    i always thought the s in my 200s stood for suspension or superawesome
    Runners:
    84 200s
    05 rancher
    12 rancher
    big yeller's Avatar
    Nov 2009
    southeast texas
    247
    woops i didnt realise i put 84 on there i did mean to put 83. cause my friend has a 84 br and yes its shaft driven...i had a 83 and it was cain driven.
    1984 yamaha 200k
    1984 honda 200es
    1985 honda 200x
    atvs:
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    Dont forget the sx
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    May 2008
    Northwestern Ontario, Canada
    552
    200s was for "sport" some said it was for "small", first came as the 200s and 185s (smaller frame versions of the same full size 200 and 185 (1980) bikes)
    200e "electric"
    200es "electric shaft"
    200x "cross" or motorcross version
    250r "racer" basically all 2-strokes
    83 Big Red (200e) was chain driven
    84 Big Red (200es) was shaft driven, had reverse attached to the awkward HI/LO range
    85 Big Red (250es) was shaft with a 250 cc engine, reverse switch on the left brake
    All kinda makes sense until you get to the 200m. That was chain driven but had electric start, never found out what the "M" was for...
    Hope this kinda makes sense...
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    S = Suspension
    ES = E-Start with Suspension
    M = I have no ****ing clue.
    R = Race
    E = E-Start
    X = Cross Platform *Race and Trails*
    SX = Suspensed Cross Platform
    The title for the 86 350x has it as a ATC350R
    Nothing to ride... for now
