Thread: Mikuni carb with no air screw? What?
    Mar 2007
    Eagle River Ak.
    129
    Hello all. I picked up a Tri-z and a Tecate awhile ago. Was looking at the carbs on both and noticed that neither have air screws on them. They are Mikunis, 38mm, have a tall, long round slide, and no external idle screw. One has had the inlet and outlet blended with a flapper wheel, other is stock. Anyone heard of these and how do you adjust slow speed mixture? Thanks. and no the screws are not missing, none of the holes are threaded.
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    '86 and '87 Tecate stock carbs have no idle mixture screws...and they're 34mm Mikuni round slides. VM34SS Mikuni's 2 B exact.
    on these carbs....there is no way to adjust the idle mixture....making pilot and needle settings more of a factor.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Mar 2007
    Eagle River Ak.
    129
    VM34ss according to the web is a carb for a yamaha sr500 with an accelerator pump. These two carbs measure quite a bit larger than a 34mm. They also have the long lever style choke instead of the black knob the stockers came with.
    787
    There's more than one VM34SS. I saw that too when I was researching Tecate carbs.
    FZ
    Southern MN
    1,875
    I agree on the tecate carb, there is no pilot screw. On the tri z carb, however, there should be a pilot screw. The carb you have on the Tri Z must not be made for it if there is no pilot screw. I had a tecate carb on my tri z for a little bit, and it didnt run right at all. I rebuilt my old tri z carb, and used the same jetting as I did in the tecate carb, and it ran a lot better. Have you had either of them running?
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
