hey guys I might be getting a 1983 or 84 Honda ATC 200 for 200 bones it runs and rides. It has electric start and recoil start. it does not have reverse. what is it? is it a 200m? 200s? or 200e?
thanks
Jordan
thanks
Jordan
1985 Honda BigRed 250ES
runs good all original
Restoration in progress:
1980 Honda ATC 110
1985 Honda ATC 250SX
1982 Honda 200ES BigRed
1984 Honda 200S
1984 Honda 200S parts bike
1985 Honda ATC 110
1983 Honda ATC 110 parts bike, runs but smokes
Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
If it has High/low range it should be a 200e. If not sounds like a 200m.
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
possibly a 200S with options. If all gears are up, it is an S
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
I agree with whiteman. Out of those 3, the 200s is the only one without electic start, so it is most likely a Big Red or 200m. Get the VIN off the neck and and go to http://atcvin.webs.com
Rob
With electric and recoil start, sounds like a E. Definitely an E if it has the "Hi Lo" gear shifter beside the recoil start. Like others said above...go to the VIN verification link.
thanks I will have to ask him if it has high/low range.
1980 Honda ATC 110
1984 Honda 200S
1985 Honda ATC 110
if you decode it this may help
atc200 1981-83
atc200e 82-83
atc200es 84 reverse
atc200s 84-86 no reverse
atc200m 84-85 Good luck....
he said that he thinks that it is a 83 or 84 model so that kinda narrows it down. thanks guys!
Jordan
1980 Honda ATC 110
1984 Honda 200S
1985 Honda ATC 110
Its not a 200s unless it has a aftermarket starter. Most likely a 200m. 200m has no reverse or hi/low gears but does have electric start. 200e has hi/low and reverse if I am not mistaken.
Tyler
85 ATC 250r -Under Construction
86 TRX250r
05 KFX400
02 400EX
also if it has front and rear racks it is most likey and E I have an 85 200m the biggest tell tale is the high low range selector. Electric start was only on the M and E models. The M had electric start but no racks or hitch from the factory. The M and Ehad bigger tires and wheels than the S model and if i am not mistaken is overall just a big larger then the S. S models are sought after for the fact they seem to be the fastest of the no rear suspension models. All good bikes all had a recoil start. if it does have a front rack another easy way to tell is the mounts for the front rack on the E model were built into the forks the front rack for an M has brackets to mount it.
1986 350x
1985 250es Big Red
1985 200m - sold
1984 225dx - sold
JCPenny Scat Tracker
1977 atc 90
2002 custom Suzuki Volusia
1983 XL250R
1975 XL175 (needs alot of work)
1965 S90
Proud Owner of 1 Set of Trailpros
this trike has a rear rack and a hitch I think and no suspension.
1980 Honda ATC 110
1984 Honda 200S
1985 Honda ATC 110
No suspension at all?? Then it is older than an 83, and it's none of the trikes discussed in this thread.
Rob
