Results 1 to 15 of 22
Thread: 200s carb leak
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    200s carb leak
    Cleaned out the 200s carb lastnight and its leaking gas out the overflow on the top now.....
    The float and needle looked good and didn't seem to stick, any ideas on what else could be causing it, the bike still runs but the gas leaks out the hole and runs down the carb onto the motor..... until i turn the petcock back off of course...
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Feb 2009
    michigan
    2,387
    gotta be the float or pin
    1985 ATC 250R
    . Team Red Trike
    Trimotomike's Avatar
    Trimotomike is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2008
    Crystal River , FL
    233
    float adjustment for sure , If you have a plastic float your s.o.l. My suggestion would be to spend $40 on a brand new carb from ebay and youll be good to go . They ebay carbs even have a metal frame for the float so you can adjust it down the road if needed . I beat my head up against a wall for weeks trying to figure out why my original carb was acting up and leaking fuel out the overflow non stop . Some people frown upon the knock off ebay carbs but ive been using them on all my trikes and they work great .
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    Jan 2008
    Crystal River , FL
    233
    http://cgi.ebay.com/ebaymotors/Honda...item414bed9fac
    Its a few more dollars that I paid for mine but here it is , matches the original carb to a tee
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    Apr 2007
    UP of MI
    804
    Buy a $20 rebuild kit, adjust it properly and it should be fine. There should be no reason to get rid of the plastic float unless you broke the tang off that the float needle sits on.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Feb 2009
    303
    It was cleaned properly and new gaskets installed, it just still leaks, the float tang, float and needle are all good, and all the jets where cleaned properly and work good, the bike runs great, its just spewing gas like the floats bad.... WEIRD
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    I don't want to have to get a replacement carb, im too strapped on cash right now and i still need to get break cables for it.... Looks like the carb comes back off tonight when i get the header gasket installed the old one leaked....
    Tusk Hand Guards
    TAG handlebars
    Jan 2008
    Crystal River , FL
    233
    Im tellin ya replace it !!! you wont be dissapointed
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    Feb 2009
    303
    no $$$ if i had the $50 i would replace it and be done with it!! It will have to be done some other way for now...
    Tusk Hand Guards
    TAG handlebars
    Apr 2007
    UP of MI
    804
    Quote Originally Posted by juggaloclownz18 View Post
    There's a difference between cleaning and rebuilding. Rebuilding replaces everything that's worn, which can be a lot of things in a carb. Just because it looks good doesn't mean it's good. Get a new float needle. I would do the same with the jets. Can you tell that the jets are still the size that is stamped on them just by looking at the size of the hole? I sure can't. I'm not trying to be a dick, I'm just trying to help you get it running without pulling your hair out.
    1973 Honda CB350
    1973 Honda ATC70
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Jan 2008
    Crystal River , FL
    233
    If your strapped then you need to try to adjust the floats somehow , chances are your set to high , I would think thats causing it to flood gas out . I have an extra float thats metal if you want it its your just PM me some shiping info .
    2003 RM125 mine
    1991 CR125 fiancees
    2001 CR80 sold
    1985 KLT110A
    1982 YT175 sold
    1983 ATC185s sold
    1984 YT200 sold
    1983 ATC200x sold
    1983 ATC200 sold
    3wheeledjunkie is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Maysville, Kentucky, United States
    247
    Hey pull the bowl off, fill with gas till it almost spills over. If it comes out the overflow at the bottom, then the overflow tube, (brass tube molded into the bowl), may have a hole in it. Have had it happen at work, stumped us for a week the1st time it happened. I assume you are talking about the hole at the bottom of the carb bowl is where it's leaking from correct? There should be no overflow on the top of the carb, it's a vent. If gas comes out that hose, you got major problems, not likely float related.
    1985 ATC250ES Big Red, Low Hours,
    1983 ATC185 200S jug, need crankcase or for sell
    1985 ATC110 Stock, Hondaline headlight guard
    1982 ATC70 Fun
    IT'S A HONDA
    Feb 2009
    303
    Im def. not talking about the hole at the bottom of the float bowl, but rather the "hole" on the side thats right above the choke lever (not where the gas line goes but to the left of that).... Is that bad????
    Tusk Hand Guards
    TAG handlebars
    Oct 2009
    247
    No gas shoudl ever come from there. I have no idea what could be causing it to get that high, is it a steady stream or like a vapor kinda leak? May just not be venting right?
    1982 ATC70 Fun
    IT'S A HONDA
    Feb 2009
    303
    Its a steady stream of gas that comes out until i shut the petcock off again, happens weather its running or not....
    Tusk Hand Guards
    TAG handlebars
