Results 1 to 15 of 22
Thread: PW80 Cylinder and Piston on Tri Zinger YT60
    Dec 2009
    deer park, wa
    4
    Looking for a little more power out of the little zinger. Has anyone put a PW/BW80 cylinder and piston on these? Will it fit? If not, what are some of the other mods people to to get more power out of them? Thanks
    OK
    5,450
    I don't know, but I'd be interested to hear if anyone has done this..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    I hope it is possible.....
    I feel bad for FOX, he's been looking for a good cylinder for a long time now!
    OK
    5,450
    I've got 2 or 3 used cylinders.. I don't know if they are any good.. How would I check?
    Rides:
    My feedback thread
    Dec 2009
    deer park, wa
    4
    I am going to try and find one and see if it will fit.
    Sep 2006
    Northwest Indiana
    1,893
    I believe a E-ton 70 cyl is the closest. Plus, some of their pistons can be used as oversize in oem tri-zinger cyl. I had all of the 'interchange info' it one point from my yamaha friend who was big into this stuff 7-8 years ago. There are options, and i'll try and get this figured out at some point.
    Nov 2002
    Kirkville, NY
    3,831
    What are the options?
    So far I am trying to get some bigger pistons out of the UK and I have heard the Honda Express oversized pistons may work as well. I have 2 junk cylinders here and another one that may be usable on the way.
    I have not tried the PW80 cylinder just because I have not heard of anyone beeing able to use it yet.
    Were these coated from the factory?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Nov 2006
    southern oregon
    2,338
    I am not very familiar with these engines, But I would like to suggest buying a base gasket for the PW before spending the money on a jug.. you can then use the base gasket to determine if the cylinder studs are in the proper location... do the engines have the same stroke?
    2-stroke lover
    OK
    5,450
    Good idea..
    Rides:
    My feedback thread
    Baltimore, MD
    6,088
    If you want to put a larger cylinder on a zinger, you have to do pretty much what greenhuman does to the 200x cylinders. You need to build up the cases with welds, then you need to redrill your cases for new studs in a different location and then you need to machine out where the bottom of you cylinder fits into the cases. Without doing this, well, it's just alot of work for very little return.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2009
    deer park, wa
    4
    Few more questions. I want to block off the pre mix stuff and mix my own gas. What all is required? What kind of throttle cable do I use?
    What is the STD bore on the Zinger? Thanks
    Racerguy381's Avatar
    Racerguy381 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Puyallup, WA
    265
    I have a friend that has a PW50 with the PW80 cylinder on it. When I see him I will ask what it takes to do the swap. Not to familure with the Zinger so I dont know how close the engines are. Anybody on here know how different they are?
    Trikes
    1985 Tri-Z 250 Piped ported and PV'd
    1985 ATC 250R trail destroyer!
    1984 ATC 70 rebuilding
    1982 ATC 70 stut wheeler drag bar an cooler rack equipped
    1973 ATC 70 searching for parts...
    Bikes
    2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
    1988 KX500 The Beast!
    1986 KX540 In search of parts!!! Help if you have some
    1982 CR480 Unlimited Evo Racer
    1982 CR125 Unlimited Evo Racer
    1982 YZ100 cheater bike...
    1981 KX250 Unlimited money pit Evo Racer
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by xlxrman View Post
    Its pretty easy to block off... I took the pump all the way apart, used a small rubber washed on a tight fitting bolt with a steel locknut, and then tack welded the nut to the bolt, and sealed for extra protection (from the outside) with epoxy... Using the stock cable still, without issue. (just removed the injection cable)
    Baltimore, MD
    6,088
    You can buy all the stuff, cable housing, cable, and ends from Dr. ATV and then you have to custom cut and make your cable to size is the easiest way. There may be a motorcycle cable that fits, but I checked 20 or so cables and never found one myself. It was easier for me to cut and assemble my own.
    Nicholson 185s
    Dec 2009
    deer park, wa
    4
    I've heard of a lot of people bolting on the YT60 cylinder to the PW50, so if the PW80 cyl. fits on the 50, it should fit on the zinger.
