Results 1 to 15 of 20
Thread: 1989 Ram Charger....318. pros, cons??
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Going to look at one this weekend. Has some goodies done to the motor, can't remember of the top of my head...fresh rebuild, headers with duels....37" tires but comes with the originals as well, Warn manual hubs...automatic...needs inspected, runs well according to the seller. He's asking $1200obo. It has 85,000 miles on it...
    I'm just looking for pros and cons of this. I know their fuel mileage is terrible with the 318 or the 360...Dad had a '89 Power Ram a few years ago with a 318 and I loved it.. Anyone that has owned one or worked on one, give me your input please.
    TF 07,08,09,10,11,12,13,14!
    Dec 2009
    the ville illinois
    477
    ive had several dodge trucks and ramchargers and in my opinion they cant be beat!
    Rawlins350x's Avatar
    Rawlins350x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2007
    Cairnbrook, Pa
    158
    i have a 318 in my jeep.. had the dang thing for 9 days and hydrolocked the motor.. lesson learned. I will tell you that gas mileage sucks, but the pickup is worth it.
    Sep 2008
    845 New York
    2,302
    my uncle had one same year i think easy to work just never got it running cant remember why...
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Eastern Long Island
    1,688
    It should be a good truck. I'm guessing it's still throttle body injection, 3 speed auto? I ad an 89 250 and it was a beast. The only problems I had were an intermittent fuel pump that drove me nuts until I figured it out. It would run fine for days then you would drive it somewhere and it wouldn't restart. Come back a few hours later and it would start right up and run for days. When I pulled the bed to change the pump I found that the last guy to do a pump kinked the lines when he put the tank back up and caused the pump to overwork itself. The 727 transmissions sometimes leak down internally if they sit for a few days and the truck won't move unless you let it idle for a minute or 2. Mine did it for the 2 years I owned it and I never had a problem.
    Lots O Trikes!!!!!
    Ontario, CANADA
    4,538
    Rusty,
    I know my truck is a 2wd but with all my states trips at 5+ hours, I was pulling 20-23 mpg with my 318 doing 70-75 mph.
    Keep your foot outa it and its ok, put your foot into it and ive had like 12-13! haha
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Manheim, PA
    5,816
    my g/f had a ram charger, i think it was a 1989 also. she loved it, but i belive she said hers had a 360 in it. only thing she didnt like was not being able to ride the brakes alot going down a big mountian road. she told me if you did by the time you got to the bottom you had no brakes hardly.
    Oswego NY
    1,935
    My first car was a 81 ramcharger!! I loved that thing!!! 218000 miles when the rear body mount rotted out & the gate stopped working. I did put a trans in it @ 145000, but my fault, threw a driveshaft, it bounced & hit the transfer case, cracked the trans body.
    I'd have 1 if i could find a nice 1
    MIK6 / Mike
    New England Ride 4/13
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    the motor is indestructable in its stock form, the tranny is also very tough. Rear seals are known to go, no big deal. Bad milage, as others have said. Great 4x4 though. Warn hubs are not as good as the stockers, id find some in a wreckers and swap back.
    Crawl under it and check for leaks. What kinda goodies on the motor?
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Monroe MI
    5,786
    My brother had one with 318, he plowed with it.
    The body rusted away (it was around salted lots all the time), but the engine always ran strong.
    Feb 2009
    michigan
    2,387
    just check the frame for rust.tough as nails truck though.
    1985 ATC 250R
    . Team Red Trike
    phreakboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Coatesville,PA
    358
    Ive have had a few ramchargers over the years and loved everyone of them. From what you describe, that is a very good price. They are great suv's if you want to class them that way. Dmv will say their a station wagon. Awesome on road and off road and very reliable. The 318 is a bulletproof motor and will run and run, one of mine made it to 285,000 miles before I sold it and it still ran great. The hubs were most likely changed to get rid of the CAD (central axle disconnect) system. I swapped them on my 85 for the same reason and never had a single problem with the warn hubs, stock was just automatic hubs.
    Since you said its running 37's it must be lifted quite a bit, what kind of lift was used? Make sure its not just a bunch of stacked blocks between the axle and leaf spring. Also you want to find out what was done for drive line angle. Anything over a 6" lift and drive line angle becomes too extreme unless other stuff has been done to avoid this issue. You dont want to end up throwing a ton of u-joints.
    One of the few problems they do encounter is sloppy steering, but that is easily cured by a borgeson steering shaft. $200
    For more info check out
    http://www.ramchargercentral.com
    Great forum with lots of great people.
    1971 ATC90
    1984 200s
    1983 Autox
    1985 200x
    198? Yamaha 125
    (2) 1985 250sx's
    1974 Trail 70
    1991 Honda Cub90
    1974 Yamaha 125 Dirtbike
    1972 Kawasaki 175 Dirtbike
    (2) 1980 Chrysler Sno-Runner
    (7) 85-87 Toyota Mr2s
    (2) 1985 Dodge Ramchargers
    1968 Mustang
    1972 Beetle
    2004 Dodge Ram 1500 HEMI
    1984ATC200S's Avatar
    1984ATC200S is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    New Brunswick Canada
    222
    we run a 318 in our plow truck, thing is a beast, 4 barrel carb, lil prime and it fires rite up no matter the weather. if its on the road for 1200$ id do it, my next truck is gonna be an 83 dodge ram 150 4x4 with a 318, cant wait for spring to get to work on it.
    1984 200s
    1984 big red
    1980 Kawasaki Invader 340 liquid
    1993 GMC sierra, 4.3L automatic
    1990 Chev Scottsdale -parts
    1989 Chev wrangler 4.3L 5 speed- parts
    Chevs are for parts GMC's are for driving
    83ATC185S is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2007
    Show Low, Arizona
    291
    I would check what gear ratio if has, if its stock the transmission is probably hurting trying to turn 37's. big tires and a stock axle ratio will eat transmissions,too much heat
    Dec 2009
    the ville illinois
    477
    so.......whats the scoop? did you get the ramcharger???
