Results 1 to 9 of 9
Thread: Tecate flywheel tool
    luke's Avatar
    luke is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    Scunthorpe, England
    209
    I just got a flywheel puller from ebay, and it dosen't fit the flywheel.
    Partly my fault for not looking first, but there are no threads on mine for the tool to go on to. I saw it and bought it without giving it a second thought. What do you guy's use or is there another i can buy ?
    This is the one i got -
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
    198? Manco Quester 300
    1983 KLT 200
    1984 Tri-Zinger 60
    1985 ATC 70
    1985 TRI-Z
    1985 TRI-Z (two Wheel)
    1985 ATC 250R
    1985.5 TRI-Z
    1986 TRI-Z (quad)
    1986 Tecate
    1987 Malaguti Ranocchio 50
    2001 YZ 250
    Sep 2008
    Northwest Indiana
    550
    That tool is for KX flywheels.
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Jun 2003
    englishtown NJ
    2,676
    I used to have a homemade flywheel tool, it basically was a round piece of aluminuim 1/2" thick, it had three slots in it that the flywheel bolts into and the center has a threaded hole tapped with a 2" 10mm bolt that presses against the crank. It looked really easy to make.
    http://pictureposter.allbrand.nu/pic...3/IMG_0867.JPG
    Southern MN
    1,875
    Hey jeswinehart, thats a steering wheel puller, right? Good idea....
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    eyecekold1's Avatar
    eyecekold1 is offline Check my feedback before buying from me First time rider
    Oct 2009
    Provo Utah
    209
    This works out nice it looks just like jeswinehart's tool. You can get these at Auto Zone and Harbor Freight for like 15-20 bucks.
    http://www.harborfreight.com/cpi/cta...emnumber=37824
    85 350x 12:1 piston and porting by "boosted96cobra"
    4 85 tecates 1 runs
    5 84 tecates none run
    1 84 Yamaha Zinger, mildly ported & polished, milled, bored .25 over finally running
    2 atc 90's just parts bikes
    00 rm250
    93 kx500
    2 Honda 200m parts bikes
    Sep 2005
    MICHIGAN
    2,027
    I went to Autozone and bought a harmonic balancer puller.
    86 T3
    84 T3
    86 KX250
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Quote Originally Posted by nd4speed View Post
    That's the 1.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Racerguy381's Avatar
    Racerguy381 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Puyallup, WA
    265
    Simple to make if you have some scrap metal a welders an a decent size nut an bolt. Drill a few holes or slot them for a multi use tool, one big on in the center. Weld your big nut in the center hole and I would gusset it on the sides so it doesnt warp. Some of them flywheels are on like a mother.... Simple enough
    Trikes
    1985 Tri-Z 250 Piped ported and PV'd
    1985 ATC 250R trail destroyer!
    1984 ATC 70 rebuilding
    1982 ATC 70 stut wheeler drag bar an cooler rack equipped
    1973 ATC 70 searching for parts...
    Bikes
    2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
    1988 KX500 The Beast!
    1986 KX540 In search of parts!!! Help if you have some
    1982 CR480 Unlimited Evo Racer
    1982 CR125 Unlimited Evo Racer
    1982 YZ100 cheater bike...
    1981 KX250 Unlimited money pit Evo Racer
    luke's Avatar
    Nov 2007
    Scunthorpe, England
    209
    Thanks guys, if this one fit's the Z i'll keep it. Looks like i need to find one like in John's pic
    1983 KLT 200
    1984 Tri-Zinger 60
    1985 ATC 70
    1985 TRI-Z
    1985 ATC 250R
    1985.5 TRI-Z
    1986 TRI-Z (quad)
    1986 Tecate
    2001 YZ 250
