Results 1 to 12 of 12
Thread: 85 atc 125 motor swap lifan??????
    saladboy's Avatar
    saladboy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    michigan
    178
    I just pick up a 85 atc 125,it runs but the trans is shot.(i think,hard to shift gears)anyway i saw a lifan 125 with ele start and a semi-auto trans.Is this a direct bolt in?how about the electrical system,can i use the honda wire harness?what about power is the lifan as good as the honda?i'm a little leary about the china motor,but i'm kinda limited.I would like to rebuild my honda but in feb. 09 I lost the use of 60% of my hands and a leg and its kinda hard to do that kinda work.I do not want to give up riding trikes so i thought a china replacement might do the trick.what do you all think.
    Oct 2009
    Missouri, United States
    62
    From what I understand, the china motors have a different bolt pattern than the 90/110/125 motors, but i dont know if they will bolt up or not. As far as power goes, I think it would be about the same.
    TRIKES:
    84 ATC125M
    85 200 M
    83 ATC110
    QUADS:
    85 TRX125M
    01 Blaster
    08 SunL 110
    87 Yamaha Moto4 200
    DIRTBIKES:
    78 XR75 Restomod
    2009 SSR125 Pit Bike
    82 XR200R with Powroll motor
    78 RM80
    Chinese Z50 Knockoff
    82 XR80
    Lancaster, PA
    1,738
    the Lifans are a different pattern , it is not a "bolt up", but you could make it work
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    saladboy's Avatar
    Oct 2006
    michigan
    178
    cool,thank for the info.
    Baltimore, MD
    6,088
    You can buy an adapter like edog did when he put that engine in the atc90 frame. Or you can drill different holes. The lifan is based on the atc70,z50 engine cases and it is smaller than an atc90/110/125 engine.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2010
    falmouth kentucky
    no actually, i have delt with a few lifans, most forward piston engines have the rear and top mounts, which are all identical, honda yamaha suzuki kawasaki lifan, heck you could put a crf 50 engine in there if u wanted to!
    Dec 2010
    falmouth kentucky
    post pics of that 185 with suspension!!
    Nov 2009
    1,147
    If its just hard to shift, have you tried adjusting the auto-clutch, and run some good motorcycle grade oil in it. The tranny on my Trail 90 was terrible to shift when I first got it running, it had sat for 10 years. Changed the oil a lot, almost every ride, then once it cleaned out in there started running Valvoline 10W40 motorcycle grade oil, it shift great now. Also if the idle is too high it made it harder to shift, that was just on mine.
    I certainly wouldn't give up on a Honda to swap in a Lifan when all that's wrong is being hard to shift. Have you sprayed at crap out of all the pivot points on the machine with a penetrating oil of your choice. If it goes through all the gears the tranny should be fine internally. I would suspect the clutch might not be releasing enough. It will be a lot less work to make it's engine shift good.
    Before anyone adds to this I looked at the top and this thread is really old......
    Dec 2002
    deer park, texas
    2,336
    Quote Originally Posted by jerniganatc350x View Post
    No........
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    OH HELL NO THEY ARE NOT!!!!! you can not bolt a lifan directly into a atc90/110/125... it will not directly bolt in.... i have been installing lifans for years!!!! your dead wrong, bad info,,,,
    KASEY's Avatar
    4,239
    that happens alot when new members start looking around , to bad he knows not what he speaks of!!!
    big schott's Avatar
    big schott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2007
    Western Minnesota
    244
    Kasey is right, the chinese (lifan) engines are based on the Honda 70. The Honda 90 , 110 , and 125's are a larger motor and will NOT bolt up. I'm not sure if the power of the smaller 125cc can compair to a larger 125cc. Maybe someone can chime in on this one.
    1978 Honda 90 / 1979 Honda 110 / 1983 Honda 110 Racer (in the Works)
    1973 Honda 70 / 1983 Honda 70 / 1983 Honda X-mas special / 1984 Honda 70 / 1985 Honda 70
    1985 Honda 200X Stock Original
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
