Thread: Fork swap - ATC 200M 84 to 85
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    Ok i had a thread posted about my wiring gremlins i have been having. I am trying to switch the good front end of a 85 atc 200M chaindrive to a 84 atc 200m Shafty. The ignition on the 84 is busted out so i was going to use the ignition from the 85 which is in great shape. Upon tear down, the physical size of the key switch on the HUD is different and wiring is different. There is no reverse light either. i have isolated where the wiring goes with my clymer manual, and was hoping someone would double check what ive done here so i dont go chopping up wires for nothing. wiring the key should be as follows?
    84 ------------------85
    Black -------------- Black/White
    Darkgreen -------- Darkgreen
    Red ---------------- Red
    Red/Yellow --------- Black
    pic of the 84's wires
    pic of the 85's wires
    Everything else is the same wiring wise from what i can see. If anyone can help me out here that would be sweet.
    Cheers,
    Cox
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    1984ATC200S's Avatar
    1984ATC200S is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    New Brunswick Canada
    222
    the shaft drive 200 is an ES not an M, and they changed the wiring in 85, i no that's not really any help, but it may make it clearer
    1984 200s
    1984 big red
    1980 Kawasaki Invader 340 liquid
    1993 GMC sierra, 4.3L automatic
    1990 Chev Scottsdale -parts
    1989 Chev wrangler 4.3L 5 speed- parts
    Chevs are for parts GMC's are for driving
    Mar 2007
    Texas
    5,045
    look at my site to see about a possible manual. link in my sig.
    green is usually power and black ground.
    then hook red to red and then w/blk to yellow/red that may work. i had to do some rigging on mine too. test lite and volt meter with curcite testor for conenction worked great!
    ________________
    https://www.mikesatvfix.com
    cox's Avatar
    Aug 2009
    552
    yes i knew it was an es i just never put that. i am aware of the differences between the two. i have the full wiring diagrams for both trikes. i was hoping someone who has done this maybe or has had electrical experience to look at the diagrams.
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
    cox's Avatar
    Aug 2009
    552
    bumpity bump
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
    3wheeledjunkie is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Maysville, Kentucky, United States
    247
    Green on the older bikes is almost always ground. Black was used for misc. power. I know for a fact the Handlebars switch wires (coming from the switch) on the 84-85 200M's are different. I don't know about the wires coming from the harness. If you have a reverse light. the dash isn't a 200M, probly a Big Red. So are you swapping harnesses or? I'll double check your wring in the morning.
    1985 ATC250ES Big Red, Low Hours,
    1983 ATC185 200S jug, need crankcase or for sell
    1985 ATC110 Stock, Hondaline headlight guard
    1982 ATC70 Fun
    IT'S A HONDA
