Hi everyone! A couple days ago my uncle gave me a 1983 suzuki alt 125. It had been sitting in a garage for about 2 years. I got it out today and checked/ looked it over. *note* It was parked due to a fuel issue so thats where i started:
First i cleaned the fuel pump...the diaphrams felt a little stiff, but no leaks(dont know if this could be the problem?)
The gas tank was empty and debris free.
I took the carb completely apart and blew out all the passages(they were all clean for the most part) the only thing i had a question about was the primer on the side of the carb?i put fuel in the tank and pulled the knob out a couple times and it went back in like i thought it should but about the third time it stayed out...is this operating right?
i checked all the fuel lines and vaccuum lines...all were clear and in good shape...
The ONLY way i could get fuel to the carb is to completely cover the inlet side of the carb with my hand and pull the rope...with the excess fuel in the carb, it would run for a few seconds and die...
Is there anyone who has any idea what the problem is with the fuel system??
Thanks- Alex
