Results 1 to 15 of 28
Thread: Question about 82' 110cc - Question about 85' I could buy
    QCR77's Avatar
    QCR77 is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    SA TX
    538
    whats up everyone. its great to be a part of your community. I understand how helpful forums can be and all of my research pointed to this one! I recently bought an 82' Honda 110cc off of craigslist to cruise around the pits at the dirt track where i race. (stock cars) i got it for 350 and put 50 into a tuneup/parts it needed and its running great. its perfect for what i wanted - lightweight and doesnt take up too much space in the back of my truck. i do have some questions though and i also need some advice on possibly purchasing another one. i really did buy that little 110 solely for the purpose of convenience at the track, but dang its fun to ride through the trails of the woods behind my house. and whats better than riding trails - riding trails with a buddy ! so here are my questions and i really do appreciate any info/advice that i might get.
    about the 110cc- the part i had to buy was the cam chain tensioner springs, the little screw in tensioner and the bottom bolt with washer. the little silver tube was still in there. so i installed it and it seems great but i cant tell if the slight metalic noise is the chain or the cam chain rubbing. when i say slight, i mean you have to listen real hard for it. and you can only hear it when you rev it up and let off real fast. is that just the chain recoiling a little? and when i installed the tensioner i just screwed it all the way up in there. i understand there is another tensioner that runs horizontal as apposed to the vertical one i installed. any input on the cam tensioner would be great.
    on the side with the pull starter , up closer to the seat, there is a splined bolt that comes out and to the left of it is an "N" with a arrow pointing at the little bolt with splines on it. i know this is a prob a dumb question and i have my ideas, but what is that for?
    on the carb towards the top , right in the middle, is a nipple with no hose on it, and if you rock the atc gas will trickle out one bubble at a time. i know this aint good, but dont have a manual to figure out what/where to run a hose.
    about this 85' for sale- its a ATC ES 200. looks kinda goofy actually. like its a trail trike. anyway its in decent shape. the guy wanted 800, but i offered him 450 so he calls me and says that he used to ride it all the time at his ranch, but he bought a rhino. he said it has a new battery, but it wont start unless you pull it with something and drop it into gear. once running he said you can do whatever you want, go wherever, no prob. he thinks the carb needs to be rebuilt but that makes no sense to me. he said when you try to start it, it will just rur-rur-rur and every now and then you'll get pops (combustion) like it wants to start. what do yall think? and feel free to ask for more info, cause we talked for a while. i just gave the abreviated version.
    once again, thanks in advance for anyone that is willing to help abd i plan on learning about these ATC's and passing the help onto others.
    Nov 2008
    ontario
    1,055
    the 85 is most likely a 250 big red
    proud owner of a trx300ex quad and an 85 atc 70
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    Quote Originally Posted by daniel_250r View Post
    is that good or bad? i googled it and it does indeed look very similar
    Nov 2008
    ontario
    1,055
    i would take an 85 over my 84, main advantage is rear suspension and much better front as well
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    so should i offer $400 and then spend $50 to fix it ? i just think if it runs, and the only prob is getting it started then it might be an easy fix
    Nov 2008
    ontario
    1,055
    i doubt you will regret it
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    ok. fair enough. there is also a 200s that looks a little sportier and the guy wants $800 OBO. so i could prob offer $600 for a 200s that runs and starts perfect or $400 for a big red that runs but has starting issues. what would you do ?
    May 2009
    Brampton, ontario
    686
    the starting issue is probably a stator. its a common problem when they start getting weak and are going to die out soon. no way its the carb if it runs nice after u get it going.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    May 2009
    Brampton, ontario
    686
    i would take a 250 bigred over a 200s, but thats just me
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    Quote Originally Posted by Lukeatc185 View Post
    are you saying the stator is gonna die soon or the engine as a whole is on its last leg? can you find new or used stators? how much we talkin about ?
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    yeah my buddy liked the big red with the racks n stuff. i understand that its a classic and prob very good on trails n stuff, but to me the 200s is much sportier looking and seems to be more versatile. but then again i dont know jack about atc's yet.
    May 2009
    Brampton, ontario
    686
    if it runs nice when u pull it. its either compression or stator. so just test the compression. if its got compression. its most likely a stator. and i think there around $50 im not 100% sure on that.
    May 2009
    Brampton, ontario
    686
    but u can easily test the stator with a manual. some one will surly post a manual now.. lol use a ohm meter and check the book and the stator.
    May 2009
    Brampton, ontario
    686
    if its got bad compression it might smoke alot. unless its got like a cracked head or something. but if its got low compression it could be alot of things. gasket leaking. heads cracked or warped. rings are bad. piston is bad.. or the sleeve is just worn out and you will need to bore and get an oversized piston. just things to think about. but if you go there with a compression tester. an ohm meter. you should be alright.
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    do i need a tool to test compression or do you just pull the plug and use a finger?
    id love it if someone posted a manual. once you have the manual , how do you use it to test the stator?
    sorry for the dumb questions, im just used to working on my racecar, not an atc. but im willing to learn
