Hello,
So I blew up my old 81 250r and a 98 blaster. These where the first 2 strokes I ever owned. I think I could have avoided blowing them up if I would have had more general info on riding 2 strokes. I ran the blaster WOT for long periods of time, I would gear down and engine break to slow down. I used crappy oil, I used retarded mixes. I let my 250r run lean and coasted in gear with the cluth engaged. etc etc...
So... I would like to make a small video explaning how to properly use a 2 stroke, how they are differient from 4, and include any other 2 stroke info thats good to know. Here is what I have on my list so far:
1. Brief comparisson of 2s and 4s mechanically.
2. Explain how these mechanical diffs show up in real life situations
3. Explain how to ride a two stroke (dont WOT too much, dont engine break)
4. Compare cost and time to maintain
5. Cover 2 stroke gas mixture and differient oils you can use.
6. Explain how to make sure you are not running too lean (plug chops)
7. Cover general pros and cons of both 2 and 4. (Trail riding vs other styles)
Can you guys suggest anything else a newb should know? Or maybe add some information to the points Im going to cover already.
Thanks - Jason
