ok people i finally found a carburetor on ebay that i think it might fit my atc90 take a look at the pics and let me know if it will fit? thanks guys for all your help
it's described like this?
Brand New PZ19 Standard Of Japan 19mm Carb! 1 7/8" on center mounting holes. Manual choke and built-in fuel shut off valves. THIS IS THE CORRECT CARB FOR THE MINI TRAIL WITH THE CHOKE SET UP ON THE SAME SIDE AS THE ORIGINAL KEHIN !! Why repair or rebuild when you can buy this new unit. Jets are replaceable. Fits: Honda CT-70, Honda CT90, HONDA PASSPORT, HONDA CUB, HONDA SL, DAX AND All 72CC to 110cc China made AND Honda Engines. THIS IS THE DOUBLE INLET
