ATC250r Technical Data
by
Published on 03-11-2010 02:22 AM
With Honda's success in the early Atc market and a growing Diy racing community, there existed a need for a factory built performance model. Using a fully suspended chassis, and a Cr250r derived power plant, came the 1981 Atc250r. For 1982, HondaATC250R's evolution with some minor updates, the most notable being rear hydraulic disk brakes.
In 1983 Honda came a new generation 250r. An improved engine, suspension updates including a version of Honda's Pro-link rising rate linkage rear suspension. For 1984, the ATC250R returned again with some minor improvements.
In 1985 came another generation of Atc250r. Entirely new frame, improved suspension, and a new liquid cooled engine.
General ATC250R Specifications: GENERATION 1 Production Years :
1981-1982
Engine type :
2 Stroke, Air cooled
Displacement :
248 cc
Bore x Stroke :
70.0 x 64.4 mm
Compression ratio :
6.6 to 1
Compression :
142 - 170 psi
Transmission :
5 speed
Clutch Type :
Manual
Oil Capacity :
n/a
Carburetion :
PE 23A 27 mm Keihin
Starting system :
forward kick
Fuel capacity :
n/a
Wheelbase :
46.5 in
Overall Length :
72.4 in.
Overall Width :
42.5 in.
Ground Clearance :
4.9 in.
Seat Height :
28.7 in
Front Tires :
22 x 11 x 8
Rear Tires :
22 x 11 x 8
Front Suspension :
Hydraulic telescoping forks
Rear Suspension :
Mono shock
Front Brake :
Hydraulic Disk
Rear Brake :
81' Drum, 82' Hydraulic Disc
Final Drive :
chain
Dry Weight :
284 lbs
MSRP :
$1,695.00
General ATC250R Specifications GENERATION 2 Production Years :
1983-1984
Engine type :
Displacement :
248 cc
Bore x Stroke :
70.0 x 64.4 mm
Compression ratio :
6.6 to 1
Compression :
142 - 170 psi
Transmission :
5 speed
Clutch Type :
Manual
Oil Capacity :
n/a
Carburetion :
30mm Keihin
Starting system :
forward kick
Fuel capacity :
n/a
Wheelbase :
46.5 in
Overall Length :
n/a
Overall Width :
n/a
Ground Clearance :
n/a
Seat Height :
28.7 in
Front Tires :
23.5 x 8 x 11
Rear Tires :
22 x 11 x 8
Front Suspension :
Rear Suspension :
Mono shock
Front Brake :
Hydraulic Disk
Rear Brake :
Hydraulic Disk
Final Drive :
chain
Dry Weight :
298 lbs
MSRP :
$1,727.00
General ATC250R Specifications GENERATION 3 Production Years :
1985-1986
Engine type :
2 Stroke, Liquid Cooled
Displacement :
246 cc
Bore x Stroke :
66.0 x 72.0 mm
Compression ratio :
8.0 to 1
Compression :
142 - 170 psi
Transmission :
6 speed
Clutch Type :
Manual
Oil Capacity :
n/a
Carburetion :
85' 32mm Keihin, 86' 35mm Keihin
Starting system :
forward kick
Fuel capacity :
n/a
Wheelbase :
51.0 in
Overall Length :
74.6 in
Overall Width :
n/a, adjustable
Ground Clearance :
n/a
Seat Height :
29.9 in
Front Tires :
23.5 x 8 x 11
Rear Tires :
20 x 11 x 9
Front Suspension :
Rear Suspension :
"Pro-Link" + Mono shock
Front Brake :
Hydraulic Disk
Rear Brake :
Hydraulic Disk
Final Drive :
chain
Dry Weight :
293 lbs
MSRP :
$2,298.00
