Do they make lift kits for 3 wheelers...I have a 84 200s and wouldnt mind alittle more ground clearance
Daily Driver 1992 Chevy Silverado sitting on 35's
Toy 1984 Honda 200S
you could make one with a welder, but you wouldnt get more ground clearance becasue the rear axle will still be the same height off the ground, the frame will be higher though
83 Yamaha 225DX
84 Yamaha 225DX
84 Honda 200s
78 Kawasaki 175 enduro
83 Susuki LT250
02 Bombardier Traxter
Bigger Tires...
keep in eye peeled on ebay for front fork extenders, they move the front wheel 2 inches forward and a few inches taller, and then like mcderry said bigger tires, if you go mud tires you need to use a lite tire otherwise you'll kill that poor motor trying to turn over some huge meats
Big TIres, Change Counter Sprocket Gear to a smaller one. Front tire OPtions are limited in a 4/130 bolt pattern. Could build a spacer and use a ITP 10 rim it has a 1 inch from center offset. If you go taller you will want to go wider aswell.
going to a 27" tire will put you up 2.5" at the axle and engine cradle.
i used a 4 on 130 front hub on my 110 and then used a q-sport 9 inch gold aluminium rear wheel.
just letting you know of another wheel option
i only had to open up the center hole to fit the honda hub
WWW.HREATV.COM
KK I am going to look around and explore my options....if there are any other options please let me know...thanks for all the help
Toy 1984 Honda 200S
If this part number is still good with Carlisle (AD16-7901) then that should be a 9x10 symmetrical rim in 4 on 150 4 on 130 pattern. This place list them so they may still have some stock. http://www.psep.biz/store/atv_wheel.htm
You could then run the Goodyear ATT912 in the front (25x11x9) and then run a aggressive 25x12-9 in the rear.
A few wheelers, + an
'73 Honda 49cc Mini Trail
'85 200 Big WHEEL
"Despite the cost of living, its still popular."
orange garbage bags!!!...I know what that means in NY!!
It's Called Work Release![]()
'85 200 Big WHEEL
orange bags allways have something to do with the county...![]()
1985 ATC 250ES, Big Red
1984 ATC 125M's, 1.5 of 'em
1983 ATC 110, BLUE!
1974 ATC 70 Pink?
