View Poll Results: Lifans good or bad?
Voters
15. You may not vote on this poll
  • They are good-same design as honda
    12 80.00%
  • I wouldnt trust them-cheap junk
    4 26.67%
Multiple Choice Poll.
Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: are LIFAN engines any good?
    Nov 2002
    Ft. Wayne, IN
    81
    jmsmilin, check out www.planetminis.com in the import section , lots of information on the Lifan , GPX, Zongshen, Jaling motors.
    Methanol, the nectar of the gods!
    Nov 2006
    Sallisaw,Ok
    11
    I have a tuk-tuk with a Lifan 150CC,I've been clocked at 45mph on a straightaway in 5th gear@10,500 rpm..And I carry alot of weight since it is enclosed.
    I'm in the process of putting Nitrous on it,I'll let you know how that goes,so far I only ahve purge.
    I have an album full of pic's with engine pic's in it.
    Mine was imported direct from Lifan China,and they are one of the biggest companies over there...The motor has held up in the few month's I have had it great.I wouldn't trust anything they welded or bolted together though...I'm still going through tightening and replacing bolt's on it..
    I've been looking at the 200cc to see if I can swap the cylinder or something to up mine since they look to be the same engine/spec's..
    I knew it was similar to honda,are they the same mounting wise also??I would like to keep a 5 speed trans though..
    Here some pic's/video so you know what a Tuk-Tuk is and get an idea of the weight that I pull with the 150cc
    http://www.youtube.com/watch?v=lB3pjGdXzZY
    http://www.youtube.com/watch?v=wPcVOzgcsuo
