Thread: Tore apart my Tri-Z with pics
    Feb 2005
    Oregon
    772
    Well this is the first 2 stroke engine I have ever took apart, i was a little worried but I did it fine, I have some pics of the componenets and of what happened.
    A little storie behind it, we were at Florence for fathers day and we were topped out on the flats, so I blipped the throttle every now and then to keep things lubericated. About 3/4 a mile down It backfired and quite, so I pull the plug and somthin came up and slapped the plug so there was no gap, my first assupmtion was the piston itself did that, but I later found ou that the tri-Z's had a squish band design, so that was out of the question. Turns out peice of the piston skirt broke off got into the cylinder bounced around and nailed the spark plug, I later found the 2 chunks off almnium responsible for this in the pipe. Looks like I was runnin to lean on my air/fuel mixture, I notced the piston is pretty discolored on the sides from heat, than agian it could make sense becuase the rings are always constantly transferring the engine heat to the cyclinder walls, and seeing how the exhuast port is always the hottest the water jackets are the thickest there and the intake port is always the coolestso it makes sense they are lookin hot there but it still looks like too much. Pics of my day....
    The two chunks of allmnuim, that makes me mad
    Cylinder wall is in great shape, no grooves, I will get it honed jsut to be safe
    Here is the severe heat, the rings are seized also
    Note the broken peice of the skirt in this pic below, thats were they came from
    Here is the top of the piston, you can see all the markings those little almnuim peices left
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Newfoundland
    5,280
    Harsh man, looks like a mess.
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    That is not too bad. I have seen worse.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Maryland
    3,077
    I had a CR80 that had two bits of aluminum in the cylinder like that....course the cast parts around the cylinder skirts also broke off and trashed my cylinder. Turns out the thrust washers on crank went out and decimated everything and I had jsut done a top end on the bike too, less than 2 hrs of run time......now I'm a crank nutt...if I even sneeze at a 2 stroke crank wrong I'll get it rebuilt....better just a bore and piston than a crank new cylinder and piston....
    Learned that lesson the hardway...CHECK THE CRANK! lol
    Feb 2005
    Oregon
    772
    Quote Originally Posted by Louis Mielke
    Thanks for the tip, tommorows project, lol
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
