I got the butt of a and pushed one out of the side, but need to remove some others. I was thinking about filling it with an air compressor, any other ideas would help. thanks Kaysen
1985 Honda atc 250R- All stock with DG pipe & UNI air filter. Many Mods to come
1983 HONDA 185s- Custom Cobra pipe- 102 main jet- UNI filter- Turf Tamers
1970 Oldsmobile Cutlass Rallye 350 all original
I haven't tried it as of yet. But some have used the water and freezing it to remove dents.
Howdy
Howdy,if youdont mind would you explain this freezing technique to me. never heard of it. Kaysen
What I was told was you fill the tank about 1/3 to 1/2 the way full of water. Then you turn the tank so the dent is down and put it in the freezer over night. Big / deep dents may need this done a couple times to get the needed results.
Someone please correct me if I am wrong.
Howdy
Don't use compressed air! I tried it on a 200x tank, it popped the dent out alright, but it also expanded the whole tank. messed the whole tank up.
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
i filled my tank up just about to the top with water then put it in my freezer it did a pretty nice job at getting out all the dent
Kaysen, a friend of mine who does auto body work used a uni-spotter on my tank. Basically it spot welds a nail to the dent then you use a dent puller to pull the dent. then grind off the weld. This is only for those tanks being repainted however
Mad max, thats seems to be the best way, IMO. I can see freezing it working but how would you know how much water to use? I feel this nail and dent puller method will be the best. Thanks, Kaysen
Mad Max's solution is the correct way to repair a dented tank. It's also a preferred way to fix dinged pipes.
You can also use a torch with a wet rag. Heat the dent to almost cherry red then cool it off with a soaking wet rag quickly. Be sure to purge the tank with inert gas first and during the process.
'02 ranxher 4x4 '83 big red '84 110, '86trx70 project, '85 bigred project
I dunno if this would work but it most likely would.
Fill your tank to the very top with some sort of soda, coke, pepsi etc
Put the fuel cap on tightly and let it freeze over night. Since fizzy drink expands when it is frozen, more so than water, is should have enough presssure to push out the tanks dent.
Ive never tried this but i bet it works!
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
Use water if your going to freeze it. Not some sort of sticky, fizzy drink. Is there any proof that soda will expand more than water ?. There are very few things on earth that expand when frozen other than water. The reason soda expands when frozen is because it contains mostly water. 100% water will expand just fine, and wont leave a sticky mess to clean up.
P.S. water freezes at a higher temp than soda also.
83 YT 175
85 ALT 125
why wouldnt the ice just take the path of least resistance up and out of the filler neck??
Haspin veteran '02, '03, '04, '05
"Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
RECOVERING Trikeaholic
"why wouldnt the ice just take the path of least resistance up and out of the filler neck?? "
The neck will most likely freeze first since their is no metal on the top. it will eventually freeze around the neck and form a seal while the inside remains water for a short time longer (assuming you have filled the tank completely with water).
Same thing goes for the petcock hole.
Holic is right, it will start to come out those holes until its hard enough to form a plug.
This method is by no means a science, but it works pretty good on large dents. Then I would use the heat/ice method to work it further out.
83 YT 175
85 ALT 125
I gave up and have it at a local body shop. It's been there for about two weeks and still not much progress! Thanks, Ill post pics when I get it back, Kaysen
