Results 1 to 15 of 52
Thread: The next 10 inch wheel buy is here Shipping update!
    Cincinnati, OH
    3,289
    Thumbs up The next 10 inch wheel buy is here Shipping update!
    .160 custom spun wheel halves welded, They have no valve stem holes so you can put them where you need too!
    the price 125 + 15 to ship!
    Here is one that was installed at TF and rode all week Itrike can confirm it!
    Here is an unground 250r hub inside the wheel too!
    These will fit the COOL 86-87 tecates Pictures for the tecates will be at the bottom
    10 inch wheel on 85 200x with 86-7 200x front hub!
    OK lets clear this up!!!
    1985-6 250r Clears the hub wont clear MOST caliper need to take 4mm off the 1st and last caliper fin
    1985-6 350x Clears hub caliper bolt on deal
    1986-7 200x WILL FIT!!
    Also will fit 1st Gen 200x with hub swap from a 86-87 200x and small amount of grinding on the caliper!!!
    1986-7 tecates clears hub and caliper with no problems
    Will not fit the Tri-z with out putting honda forks and hond hub on your triz you need 86 tripples to do so! It wont fit with just changing the triz hub to a 250r one sorry i tryed!
    "MR.Clean"
    Dec 2007
    Southwestern NY
    517
    Are they going to fix the bell diameter issue or at least remove the bead retainer "notches" that are on these wheels? I have had a terrible time mounting tires on these wheels...
    SAY IT!!!!!
    85 1/2 Tri-Z - The Trail Bike w/Inverts
    85 Tri-Z - The wifes Bike
    85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
    12 Tri-Shee - The Flat Track/TT Bike w/Inverts
    NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,238
    I have these wheels and have had not a single issue mounting tires,, different brands of tires might be the reason,, with me no issues,,,
    Cincinnati, OH
    3,289
    Quote Originally Posted by zmpolaristech View Post
    Yes they are this is why there was a huge time span between buys. Was told they are going to smooth the transistion and remove those grooves like on the 70 wheels. I can't fix something when I don't kno the issue. Thanks for bringing this up again.
    "MR.Clean"
    Sep 2011
    Ocean Beach, CA
    1,333
    i just mounted a 10in kenda front max on one of these wheels today. one serious "POP" when the bead finally set, but no struggling or ratchet strapping. must just be tire choice
    Jul 2012
    Joplin, MO
    597
    I put mine on a 350x hub with absolutely NO modifications at all.
    Love it.
    Buffalo, NY
    1,993
    I need one. How do we order
    Cincinnati, OH
    3,289
    Honda harry 1
    86t3 1
    Kevin Harry (FB) 1
    "MR.Clean"
    Borup, MN
    22
    count me in for one!!
    Central Point,OR
    465
    Put me on the list for one! Thanks!
    1985 Honda 250r
    Oct 2006
    2,502
    Honda harry 1
    86t3 1
    Kevin Harry (FB) 1
    1982atc250r 1
    yamaha225dr 1
    Mr. Clean 1
    Soutwestern PA
    2,040
    I have purchased two of these and I highly recommend them. I was able to clear my '85 250R caliper with ~1-2mm to spare.
    Honda harry 1
    86t3 1
    Kevin Harry (FB) 1
    1982atc250r 1
    yamaha225dr 1
    Mr. Clean 1
    Cincinnati, OH
    3,289
    Honda harry 1
    86t3 1
    Kevin Harry (FB) 1
    1982atc250r 1
    yamaha225dr 1
    Mr. Clean 1
    Kasey 2
    piston88 1
    "MR.Clean"
    Cincinnati, OH
    3,289
    Honda harry 1
    86t3 1
    Kevin Harry (FB) 1
    1982atc250r 1
    yamaha225dr 1
    Mr. Clean 1
    Kasey 2
    piston88 1
    Jim Nemacheck 1
    Gonna let this go on another week or so Then order them
    "MR.Clean"
    Jul 2004
    miami, fl
    91
    I will take one!
