Results 1 to 9 of 9
Thread: Picked up an '85 Tecate
    Silver Creek, NY
    86
    Picked this up yesterday for $500. So far as I can tell it needs: Front and rear shock rebuilds, plastics (gahh), swinger bearings, a kick start lever, and a front tire, plus lots of odds and ends. I'll be stripping it to the frame and thouroughly cleaning and media blasting everything. It all looks stock except for a DG silencer and a Keihin carb (dunno what size yet). I won't know what the motor need until I get a kicker. Also, how can you tell if it has a KX cylinder/motor? I thought the tecate motor was black? Also, I thought the '85 had an adjustable dog bone? I dunno, maybe it's an '84 with an '85 brake setup. Anyway, the plan is a riding resto.
    2006 LTR 450-Dasa, PC3, Fuel Intake, much more...
    1991 Blaster-3 Mill Stroker, Flotek Ported, F7, Head Shaved, Flywheel lightened, VF3, 35mm PWK, much more...
    1984 200X-Work in progress
    1985 Tecate-also work in progress
    Sep 2008
    Northwest Indiana
    550
    The easiest way to check to see if its a Kx cylinder, simply take off the pipe! If there is a bridge going down the center of the exhaust port, it is a kx cylinder. If its open with no bridge, its a kxt cylinder! Depending on certain parts of the frame, it appears that is an 1985. The 85 didnt come with an adjustable link! Both motors came black from the factory!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    OK
    5,450
    The frame judging by the reservoir holder is an 85. Footpegs are 85. The shifter is an 85 shifter as well. Looks like a real good snag. I like the chain roller too.. :-) Check your reservoir to see if it has an adjustment knob, the 85 was adjustable the 84 wasn't. We have a group for the 84/85 Tecates too if you haven't already joined.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    That is a really strong foundation you've got there. Good snag!
    Silver Creek, NY
    86
    Cool, the resovoir is adjustable. Yeah, it seems pretty solid, there is a bit of surface rust, but nothing that can't be cleaned up. These things are just so damn hard to come by in my area, I had to grab it. I had an '85 T3 back in the day, but I've missed it since the day I sold it. Gonna head to the garage and start stripping it now. I'm curious about the cylinder. Anyone know if a '91 kx125 kicker will match the splines on the T3 motor? It will just be a temporary solution until I get a new one. I just really wanna comp test/fire this thing up. Oh, and it did come with a rear fender and seat, they were just removed for the pics. The fender is shot though, and I think it's a 2nd gen all hacked up to fit. I'm gonna go join the Tecate group too.
    OK
    5,450
    Yes, the kx kicker should fit. I have a kx250 kicker on mine.
    Rides:
    My feedback thread
    OK
    5,450
    Here is a picture of a kx cylinder, and what you are looking for.
    Rides:
    My feedback thread
    Silver Creek, NY
    86
    Thanks for the replies guys. Just got done pulling the carb and pipe. It's just a plain old Tecate cylinder lol. I blasted the pipe and it came clean, ready for paint. I also cleaned the carb and everything looks in order. I took a measurement and came up with 36mm. From what I can tell it's a PJ series. Stock was a 34mm Mikuni correct? Next step I'm gonna pull the motor and hit it with fine walnut shells, then I'll pull the head and have a peak inside. If it all looks good, I may ship it to my builder to have it ported, but I haven't decided yet. Any of you guys run a raptor shock with good results, or should I stick with the 300ex shock?
    Monroe MI
    5,787
