Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: 86 Tri-Z Project
    Apr 2008
    Homer Michigan
    39
    looks sweet man
    1985 200x
    Southern MN
    1,875
    My tri Z is coming along nicely and finally a roller as of a couple days ago (I've been slacking. I got a yamaha warrior shock for the rear that I put on, and rebuilt the forks, and greased ALL bearrings on the frame. The frame is all painted and done, as are most parts. I will look like the yellow and black colored 85 Z, and must say it is looking good so far... I am working on the front end on my Z, as I am trying to put a 200x front rim,disc,and tire on, but still have to figure out whats going on with that because I had to make the spacers (200x different, and Z spacers too wide for hub.) I wanted a lower tire and rim, like the 250R has, and it should handle a little better than the 25x8-12 oem Z setup. This setup will be 23x8-11, a total of 3 inches lower! All I really have to do is put a motor in it, and get some brake parts or fix what I got. I got the motor I said I was going to, but wasnt as I expected. I didnt know if it was an 86 or not, and the guy sounded like he had one when I talked to him. But it turns out to be an 85 5 speed... The top end was off it, not like the one in the pic, and the clutch cover was barely bolted on, and I couldnt tell if it would shift. The clutch was out of it, so I inspected it and put it back in, and replaced the shift shaft which was badly bent. Had to use my shifter and kicker, and got the bottom end together. I also inspected the jug he gave me, and it had somwhat bad scoring, and has got to be bored to the max. It looks like it is heavily ported, but no extra boost port on the intake.. I measured the ring end gap, and it is out of spec at .023 in. and max in my manual is .020 in. I have another jug on the way, so if I run that, I will most likely have to buy a piston kit, and gasket set, but thats it, and it should be rolling. The lower end seemed fine, so I'll give it a try. Sorry, but I dont have any pics at the moment, and will have to get some. My comp is being wierd when it comes to installing the program for the camera, so I will have to figure that out first. I will try to get some up soon! Once again, great work, looks sweet, and hope I didnt write too much on your post.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    STL
    3,560
    Moar Pics!
    Mar 2009
    Wake Forest, NC
    80
    Quote Originally Posted by Kerick View Post
    what kind of wheels and tires are on the rear?
    The front is stock and the rears are ITP Baja black 8x8 bolt pattern 4/115 with 18x11x8 Fast Trekker's. Its a good looking wheel combo. I changed the rear sprocket to a 41 from 44 since the 18's kill top end and the engine can pull with the 6-speed. My yellow Tri-z has a 42 sprocket with 18's but 5-speed.
    Mar 2009
    Wake Forest, NC
    80
    I've been messing around and got the 3 wheeler together, went and broke her in. I'm running a Kehin carb with a 158 main, 62 pilot, clip in middle, open air box, new filter with PJ1 spray oil, DG full exhaust, ported motor, and drilled boost port, 110 mixed with 93, super-M. It seems to run pretty good, but I'm going to gauge it with others at the dirt drag at BUSCO BEACH. Thanks for all your help. With out this site it would have been a lot harder to build! Everything on the forums help.
    Southern MN
    1,875
    As I've said before, that thing looks totally sick. Great restore, and I hope it is a blast to ride. Kick some of those guys asses in the drag race at the beach. SWEET!
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Oxford,NC/USA
    22
    Sweet! Let me know when you want to line 'em up!
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Thumbs up
    very nice!!!!!!!!!!!
    Sep 2008
    845 New York
    2,302
    looks great.for some reason i just love the rims and tire set up you got on it
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Mar 2009
    Wake Forest, NC
    80
    Quote Originally Posted by code200k View Post
    Thanks man, its got that cool look for sure!
    Mar 2009
    Wake Forest, NC
    80
    Quote Originally Posted by Tri-Z 700 View Post
    Haha I like that 3 wheeler rider! Lets go riding man, anytime!
